October 26, 2018 at 6:45 am
jhjang
SubscriberHello everyone,
I am trying to simulate 2D laminar developing flow and heat transfer in grooved enhanced pipe. The details are
Diameter 40mm, Length of pipe 400mm
Inlet velocity 0.0125375m/s
pressure outlet
heat flux 50w/m^2
Results
When I calculate Nusselt number in this way…
Surface integral, Area-weighted average, wall fluxes, Nusselt number & Skin friction factor, I feel these results are not in the right pattern...
Area-Weighted Average
Skin Friction Coefficient
wall 0.048432428 (Smooth) 0.37105531 (grooved)
Surface Nusselt Number
wall 15.567972 (smooth) 14.906946 (grooved)
here the trend of results for both Nu and skin friction is in opposite order.
Please help me to calculate local and average Nusselt number and friction factor
October 26, 2018 at 7:27 am
DrAmine
Ansys EmployeePlease stop creating several threads for the same issue especially as we have started answering in the other thread. Are you now doing a 2D or 3D?
October 26, 2018 at 8:20 am
jhjang
SubscriberThankyou Abenjadj sir,
I am doing on 3D but since i was getting wrong results so i tried 2D also.
October 26, 2018 at 8:30 am
DrAmine
Ansys EmployeeJust focus on what I have already asked: Have you adjusted the reference values to match your case. The default values are not valid for every case.
Moreover what do you mean with "here the trend of results for both Nu and skin friction is in opposite order." Do you have exp. results or references?
Just to remind: Simple laminar flow you will have Cf to be proportional to the inverse of the square root of Reynolds number at external flat surface. Whereas the Nu number is proportional to the square root of the Reynolds number.
For simple basic geometries we can refer to some well know correlations.
October 29, 2018 at 10:01 am
seeta gunti
Ansys EmployeeHi,
Following video tutorial will help you on how to model the heat transfer in pipes from geometry to post processing. Please go through the following links.
Seeta
October 29, 2018 at 5:50 pm
jhjang
SubscriberHi, Seeta Gunti
Thank you for this video. I have seen this video and know some more things but still, I have the problem how to get friction factor and Nu over the curve.
October 29, 2018 at 5:59 pm
jhjang
SubscriberHello Amin sir,
I do not have experimental or reference results. here what I have the opposite trend means friction factor and Nusselt number is less for the enhanced surface than the smooth surface. when I change the reference value of length as the diameter of the pipe then nusselt number start from around 10 but when I keep the reference length as default then nusselt number start around 800-900.
I just extract the results directly using area weighted average, wall heat flux, nusselt number, and skin friction coefficient.
October 29, 2018 at 7:16 pm
DrAmine
Ansys EmployeeEnsure for well resolved boundary layer for your laminar case. You need to carry out a mesh sensitivity analysis to see if the trend is mesh dependent or not.
How big is the device Reynolds number?
November 2, 2018 at 3:26 pm
jhjang
SubscriberI have checked for Re 500 and 1000.
Sir, will you please elaborate me on how to get Friction factor and Nu number directly from the software for any case.
February 5, 2020 at 12:39 pm
atulsingh92
SubscriberHello @Abenhadj,
A question about reference values, here. (I am doing a similar case of enhanced wall tubes with grooves, in 3D and turbulent along with periodic bc)
I wanted to know exactly "how" can I tune this reference value to my case. Changing the reference value pretty much changes the Nusselt. So essentially I could end up having any nusselt nunmber, for any reference temperature.
Now when you mention "adjusted to your case", does this mean, I should look at a similar experimental setup, for a particular reynolds, know what Nusselt does the experiments show, and then reverse calculate the neccessary reference temperature to input for my case?
Or is there some other method to tune this value?
2656
2120
1347
1118
461
