heat transfer ansys workbench bewteen two objects
    • Vdbloom
    • 1shan
      ,nAre you sure you checked the last time step? You could animate the result and see if you find any difference. nRegards,nIshan. n
    • Vdbloom
      1shan nmy problem is that the heat transfer seems not to be working.nI have a cube at 60 ° C (this one is insulated) and another at room temperature with convection.nI Add an apdl command file and then use the IC command for the initial temperature in both cubes.nAs you can see from the picture, the heat is not transferred to the other cube.nnn
