Heat transfer coefficient Fluent-FENSAP
    • ZhandosBaizhuma
      Dear all,
      I have simulated VAWT icing using Fluent and FENSAP-ICE. Airflow is considered as incompressible, hence no energy equation is enabled. Droplet field and ice shapes are calculated using Multi-Fluent sequence. Ice shapes show good match with experiment data.
      My question is: how does ICE3D calculate the heat transfer without incoming data from Fluent? I searched in FENSAP-ICE manual, but couldn't find the answer
      Thank you in advance
Viewing 0 reply threads
