heat transfer of wind turbine airfoil
    • ZhandosBaizhuma
      Hi everyone!
      I am looking for some tutorials about heat transfer of wind turbine airfoil working under icing conditions.
      Please, can you share withe me?
      +1000 karma points
      Where's the heat coming from and going to?  Do you mean you want to model icing?
    • ZhandosBaizhuma
      Actually the idea is blow some hot air through the wing, and measure surface temperature, heat flux etc.
      Icing model - is the next step
      Sounds like a conjugate heat transfer problem: there may well be a tutorial with the documentation that can be adapted to your design. Note, you have a 512k cell count limit so may need to model part of the blade.
    • ZhandosBaizhuma
      Thank you sir, I will try
Viewing 4 reply threads
