July 29, 2019 at 1:36 pm
sandeepruchi93
SubscriberHello Sir/madam
Greetings of the day
I'm working on a solidification model in which fluid and solid two bodies are used. Fluid body is inside to the solid body. We filled the liquid in the cavity of solid. I have selected Pressure based, Transient state,models. In boundary conditions i have given temperature value higher then melting point to fluid and Convection coefficient and room temp. value to solid.
During post processing, i have found that there are no heat transfer from fluid to solid.
What are the possible causes of this problem.
Please tell me the solution of this problem. It'll helpful for me.
Thanks & Regards
2614
2092
1321
1108
459
