March 30, 2023 at 4:33 pm
Naufal Putra Nabahan
Subscribercurrently iam modeling a PV panel inside a plastic casing with glass thats allow sunlight to irradiate PV, glass part in fig.1 showing as color red with heatflow 700W/m2.
But the temperature result at PV panel surface inside casing as below
iam thinking the result will showing temperature contour will be square at center because the glass is rectangle and heat is uniform at the surface. So how can i model glass as transparent object that can allow radiation heattransfer?
i put radiation at top glass surface (emissivity=0,89 and correlation to ambient) and PV surface (emissivity=0,89 and correlation surface to surface) with same material common glass
March 31, 2023 at 4:16 am
Raihan Lutfianto
SubscriberI don't really get what your problem is. Where is the heat source in your model? Are you going to model the "Sun" in this case? You may explain in Bahas Indonesia if it is necessary
- Features of the check case
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Error Floating Point Exception
- Heat transfer radiation through glass
- real fundamental difference in true tension body and engineered tension
- Convergency in mass flow rate
- Function mess balance in fluid flow
- Room with Air-Conditioning Vents
- Viscous Models
5268
3299
2469
