September 17, 2023 at 5:29 pm
Shuvam Paul
SubscriberI have simulated a hydraulic jump. There is a difference in water and ambient(air)temperature and as such there is heat transfer across the water-air interface. I have used VOF model and Standard K-epsilon model for the simulation. Energy Model is activated. Radiation is not considered.
Is there any way to determine the total heat transfer rate across the water-air interface bounded between the two sections(vertical lines) as shown in figure below? Also, is there a way to determine heat flux across the same interface or average equivalent thermal conductivity or average heat transfer co-efficient at the interface.?
Also I tried to determine heat flux across a point at the interface in CFD post. But it was shown as "Undefined". While the heat flux at any point at solid boundary could be easily determined. Why?
September 18, 2023 at 3:42 pm
Ansys EmployeeIn Fluent the Heat Flux report is only available for meshed surfaces, ie not iso-surfaces etc. That's in part due to nonmeshed surfaces not having facet normals. You may be able to do something with a combination of a isosurfaces, surface transform and temperature data in Excel but it's going to be a little messy.
September 19, 2023 at 6:53 am
Shuvam Paul
SubscriberThanks for your Reply ROB.
I wanted to know if I can create an iso-surface with constant water colume fraction of say 0.7 , bounded by section1 and section 2 as shown in the above figure ? It would be of great help if I could do so.
September 20, 2023 at 2:12 pm
Ansys EmployeeYou can. Create the isosurface of volume fraction and then have a look at isoclip.
7702
4484
2957
1435
1322
