Heat transfer
    • bobd
      Dear all,
      I want to implement highlighted equation in Ansys, I'm following the tutorial (https://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node342.htm) on the Ansys site. But I'm not quite sure for which part part of the eq. I have to write an extra UDF and the where to implement it.
      Thank you in advance,
      Bob
    • RK
      Please refer to the Fluent user guide, section 9.1.3.1 for single phase and 9.1.3.2 for multi phase.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_sec_ug_uds_setup.html
      Rahul
    • bobd
      Yes, I'm following that guide, but I'm not quite sure for which part part of the eq. I have to write an extra UDF and the where to implement it. Cause for example in the udf manual they write a piece of code, for the unsteady part:
      do I have to implemented it exactly, the same, or change it to my "values"?
    • Karthik R
      Administrator
      If you are looking to simply set a UDS equation, simply activate it from the User-Defined menu -> (UDS).
      This would add a scalar transport equation in addition to the regular set of conservation equations in Fluent.
      Hope this helps.
      Best Regards,
      Karthik
Viewing 3 reply threads
