August 15, 2023 at 6:19 am
Lachlan Battese
Subscriber -
August 16, 2023 at 9:12 am
Ansys EmployeeHave you had a look at the Learning materials and Tutorials (under Help in the solver)?
August 16, 2023 at 9:27 am
Lachlan Battese
SubscriberI could not find any information which relates to my direct problem, if you could pin point me in the right direction that would help
August 16, 2023 at 10:05 am
Ansys EmployeeStart here https://courses.ansys.com/index.php/courses/intro-to-heat-transfer-in-fluids/ You may not find a direct example but instead need to pull sections out of multiple places to work out the set up. The choice of boundary conditions is also based on what you know and what you're doing, so, require some planning & reading.
7592
4440
2953
1427
1322
