Heavy rst file, 45 gb, reason
    • kaitova
      Hi, could you please advise why the rest file can be so heavy, 45 GB?
      Can the reason be mesh? Or that it is transient? The cases for 4 point lift,upending have smaller weight.
      Thank you for help
    • MTBXC
      You probably have a lot of points of results. Reduce the "Minimum Substeps" or Output Controls - from "All Time Points" parameter to another option.
    • peteroznewman
      MTBXC has the right approach, reduce the number of output time points. Doing that you could reduce the file size by a factor of 10.
      You can cut the result file almost in half if you turn off output of Strain and only output Stress and Deflection.
