November 11, 2020 at 12:44 am
Syedmuhammad
SubscriberNovember 11, 2020 at 3:15 amKeyur Kanade
Ansys EmployeeThis looks installation issue. Please check installation. Please install latest version https://www.ansys.com/academic/free-student-productsnPlease install with admin privileges. If problem persist, you we may shift this to installation team.Regards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnNovember 11, 2020 at 1:22 pmSyedmuhammad
SubscriberYeah I have install the new version and again install it. but this problem is again occurringnNovember 12, 2020 at 9:58 amKeyur Kanade
Ansys EmployeeLet me pass it to installation team.November 12, 2020 at 1:11 pmANSYS_MMadore
Ansys EmployeeArray Can you try renaming %APPDATA%\Ansys\vXXX to vXXX.old, replacing XXX with the version you are running.nnThanks,nMattnViewing 4 reply threads- The topic ‘Hello ! After completing my geometry I am trying to open meshing but it’s giving script error’ is closed to new replies.
Trending discussions- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Mesh Element Quality Display Style Not Showing
- Local mesh refinement with targeted edge lengths at specified areas
- Fluent Meshing Batch Mode – Problems workflow commands
8808
4658
3155
1688
1480
