September 12, 2019 at 2:51 pm
September 12, 2019 at 5:48 pm
SubscriberPlease attach the file.
September 12, 2019 at 6:30 pm
Georgiro1
SubscriberFine, I will do it without any problem, but tomorrow in the afternoon.
Thanks
Jiri
September 12, 2019 at 6:32 pm
Georgiro1
SubscriberNo, now it is here! Thanks Jiri
September 12, 2019 at 7:35 pm
SubscriberGeometry was repaired to return a solid body from the surfaces. You will have to recreate the features I had to delete to do the repair.
September 13, 2019 at 5:35 am
Georgiro1
SubscriberThanks a lot, however I need to understand what exactly have you done? And now I have to re-create a solid, but how? This is also my question.
Thanks
Jiri
September 13, 2019 at 5:18 pm
SubscriberJiri, what do you mean you have to re-create a solid? The file I attached has a solid in it.
It's not important what I have done. What is important is what you did to turn the solid into a surface body. You must be vigilant to check the box for Construction Curves so you don't cut the faces of your solid unless that is what you want. After each operation, you must look at the Structure Outline and make sure you still have a solid. If you don't you must Undo the last step and do it over without turning the solid into a surface body.
September 13, 2019 at 6:12 pm
Georgiro1
SubscriberSo fine, but I still do not understand and how can I find out that I have only the solid and not the surfaces? How to find this out?
Thanks and sorry for my questions!
Jiri
September 13, 2019 at 8:11 pm
Subscriber -
September 14, 2019 at 5:56 am
Georgiro1
SubscriberThis is fine and I understand it well, the only thing is to have whole one solid as one solid and not three ones, so why to have three solids? Thanks these questions...
September 14, 2019 at 12:09 pm
Georgiro1
SubscriberAnd why there are 3 objects and have the same names?
September 14, 2019 at 12:40 pm
SubscriberIn the example above, there are three solid spacers separating two surfaces that are plates. You can name a body anything you want.
September 14, 2019 at 1:05 pm
Georgiro1
SubscriberYou mean the geometry above, i. e. posted yesterday - the model. So I have looked at the geometry as you show above and there is only one solid, so what is the Symmetry of 6 mm space_1? I am a bit confused - but sorry! Jiri
September 14, 2019 at 1:08 pm
Georgiro1
SubscriberSo in this case tell me where can I get the three solids object as you are mentioning. Thanks
Jiri
Georgiro1
SubscriberI have to go outside, so it will take me more than an hour to come back and go to see your info. Thanks
September 14, 2019 at 1:12 pm
Georgiro1
SubscriberBut also my problem is how can I repair the model from surfaces into 3D model object? I have no idea! This is the problem, just to know it from you!
September 14, 2019 at 3:08 pm
September 14, 2019 at 3:18 pm
SubscriberWhen you start with a solid, it is very easy to keep checking that you have not turned it into a surface by mistake just by looking at the icons after each operation. If you see that you have turned the solid into a surface, then you just hit Ctrl-z to undo the last action. If that doesn't give you a solid, keep hitting Ctrl-z until you get a solid. Check that you still have a solid before saving the file.
You start with a solid and you keep checking that you haven't cut up the face of the solid as you draw curves as I showed at the 3 minute and 10 second mark in this video, which also shows some repair operations if you do that by mistake.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
