Photonics
Photonics
Hello I want to build a grating model to get the positive and negative first-ord
    • Qin Pan
      您好
      ,我想建立一个光栅模型,以获得光栅衍射的正负一阶光强度。这是模型的参数。它的上层是光刻胶,中间层是SiO2,底层是Si
      But the light intensity information in the monitor seems to be wrong. The diffraction light intensity at the zeroth order should be the largest, and then decrease successively, but the light intensity at plus or minus 1000nm in the monitor suddenly increases. What is the reason?
      I change the single wavelength from 400 to 500nm, and this kind of curve appears, but the energy at 0 decreases instead? Could it be my monitor added wrong?
      If a beam of plane wave is incident vertically from above, I think about the diffraction light intensity information of this model. Is the modeling method in the above picture correct? Looking forward to your reply, thank you very much!
    • Guilin Sun
      仿真应该没啥问题。
      你看的是监视器本身的结果是吧?近场不可能区分衍射级。
      你需要用光栅分析,而光栅分析是假设无限周期,因此看不到类似曲线。这是因为无限周期衍射的角宽度为零,这与有限周期有区别。
      参见例子 Diffraction grating
      Ansys Insight: 关于光栅衍射级及其计算 (目前乱码显示)
