February 14, 2022 at 11:03 am
shashi27
Subscriberhello
i want to do static analysis for a rotating beam
i want to know what should be the boundary condition at fixed end.
February 14, 2022 at 1:23 pmAkshay Maniyar
Can you share some more details about the model? If you can tell how exactly the beam is loaded then it will be easy to understand and answer your query. Is one end fixed and moment or rotation is applied at other end?
Thanks Amaniyar
February 14, 2022 at 3:05 pmshashi27
SubscriberHi amaniyar
The model is a cantilever beam with one end fixed on a hub and the hub is free to rotate. I want to know if beam is rotating at a constant angular speed, let's say 100 rad/ sec and tip load is applied, then what will be the displacement and stress generated in beam?
I hope I have given the required details
Thanks
February 15, 2022 at 7:40 amAkshay Maniyar
Thank you for the information. As you mentioned that beam is connected to hub, so you can use joint to define that connection, depending on which DOF need to be fixed or which need to be free and then apply joint load for it. Do you have some images of model which you can share? It will be difficult to imagine with this much detail and answer.
Thanks Amaniyar
February 15, 2022 at 7:53 amFebruary 15, 2022 at 7:54 amshashi27
Subscriberi am making this model in ANSYS APDL
February 15, 2022 at 7:57 amshashi27
SubscriberIt is a 2d analysis
February 24, 2022 at 6:49 pmshashi27
SubscriberHello,
No answer to the question posted above.
February 26, 2022 at 6:48 amRam Gopisetti
Ansys Employee, you can make the beam an 1D object and Hub as an shell then u can apply bonded contact between the vertex and surface and apply joint to the hub centrally,
Cheers, Ram
Viewing 8 reply threads- You must be logged in to reply to this topic.
2616
2098
1323
1108
461
