3D Design
3D Design
hello. Im having a plug in error while trying to edit the geometry for model. how to solve it?
    • Aads99
    • Aniket
      what is source of the imported geometry, are you able to open it in SpaceClaim and then bring it to Mechanical?
      -Aniket
    • Aads99
      hi aniket.im using workbench 20.2. i drew my 2D model with space claim but it was not detected in mechanical. The ansys mechanical only showed this plugin error. please guide what to do now. thanks.
    • Aniket
      can you please post an image of how your model looks like in SpaceClaim?
      kindly post it as inline image like the one you have posted in the question!
      thanks!
      -Aniket
    • Aads99
      ya sure. this is just a basic model which ive drawn. im learning from the edx course and i couldnt get past the geometry step(to the meshing)
    • Aniket
      What you have in SpaceClaim is a sketch, not a Surface which Mechanical can read.
      Please convert it to a surface first, and then you can take it to Mechanical.
      To convert it to a surface, select all the 4 curves and select Fill in the Design tab under edit group. Shortcut "F" key on the keyboard.
      -Aniket
    • Aads99
      thank you aniket. the problem was solved. sorry for the inconvinience
Viewing 6 reply threads
