February 10, 2022 at 3:18 pm
Karthi111
SubscriberFebruary 15, 2022 at 7:07 amNaresh Patre
I think this could be possible through Scripting. You will have to loop over each point to access its coordinates and then write them out in an excel file.
February 15, 2022 at 2:34 pmRahul Kumbhar
Ansys EmployeeYou can try save file as ANF file and open it in text editor. I will give you information points with its coordinates
March 2, 2022 at 3:26 pmAndrew Stankovich
Ansys EmployeeIf you want to try using scripting as a solution something like this might suit your needs.
#Prompt the user to define a save file
outputDialog=SaveFileDialog
outputDialog.Filter=”Datum Point File (*.csv)|*.csv”
outputDialog.Show
outputfile=outputDialog.FileName#Get all the datum points in the current file
allDatumPoints=GetRootPart().GetDescendants[IDatumPoint]()
#Loop through all the points and save the x,y,z coordinates to file.
with open(outputfile,”w+”) as outFile:
for dPoint in list(allDatumPoints):
X=dPoint.Position.X
Y=dPoint.Position.Y
Z=dPoint.Position.Z
outFile.write(str(X)+”,”+str(Y)+”,”+str(Z)+”\n”)
This will write the files to a csv file that can be opened in excel.Viewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
459
