Hello, what is the problem? please guide me.
    • haj
    • HDLI
      Please use RMxprt to create Maxwell 2D mode with 3 phase current or voltage.
      1). Sum of 3 phase current would be zero.
      2). Neutral point would be connected with ground while using current source and Y connection.
      3). There might be a big resistance added between current source and ground, to present infinite internal resistance of current source.
      HDLI
    • haj
      Thanks a lot.But when using the VPulse source, there is no need to connect the neutral point to ground.By connecting the neutral point to ground with a 100 GOhm resistor, the problem was solved.
    • haj
Viewing 3 reply threads
