March 4, 2022 at 4:30 pm
AbelLaguardia
SubscriberMarch 7, 2022 at 8:18 amKeyur Kanade
Ansys EmployeeCan you right click on second error?" target="blank">
Best way is to check geometry in SpaceClaim. Please check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
Also check sizing you have provided.
Please check following videos
Ansys Meshing Sizing:
Regards Keyur
March 7, 2022 at 9:49 amAbelLaguardia
SubscriberThank you Keyur. I already fixed the problem in Spaceclaim and it already meshed successfully. However my Ansys Meshing software does not really have the "check problematic geometry" option that I can click in different kinds of error. It could have been more helpful to troubleshoot meshing problems if that feature shows up
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2688
2138
1355
1136
462
