March 9, 2022 at 2:51 am
mouxin
SubscriberMarch 9, 2022 at 7:20 pmGuilin Sun
Ansys Employeehow many periods? What is the wavelength? if it is optical wavelength, you may have huge challenge simulating it in regular HPC. If it has many periods, you can approximate it to be infinite, so to refer the fiber Bragg grating example by simulating only one period.
For limited number of periods, the best method is to use EME, where you only need to have the input part, the unit cell, and the output part. how many periods? What is the wavelength? if it is optical wavelength, you may have huge challenge simulating it in regular HPC. If it has many periods, you can approximate it to be infinite, so to refer the fiber Bragg grating example by simulating one one period.
Please note: only one post is enough to get reply. Do not duplicate posts in the forum.
- Error on Lumerical device
2616
2092
1321
1108
459
