February 4, 2021 at 7:18 am
wisnukusuma
SubscriberFebruary 4, 2021 at 12:10 pmRob
Ansys EmployeeYes, it's failed to mesh because the setting would result in too poor a quality. Review the settings relative to the geometry and see what doesn't make sense: ie a minimum cell size that's bigger than geometry features or two size settings that conflict. nFebruary 4, 2021 at 12:17 pmKeyur Kanade
Ansys EmployeeThis is very generic error. This could be due to geometry problem or due to wrong mesh sizing. Can you please check following? nPlease check geometry in SpaceClaim. Select geometry in structure tree --> Use right click --> Select Check Geometry. The geometry should be error free to proceed. If geometry has any errors, please modify/recreate geometry at those places.nIf geometry is error free, then please select correct Physics Preference in meshing. nPlease give body/face/edge sizing so that mesh has sufficient mesh density and resolve important features. nFor the error, please use right click on the error and click on 'problematic geometry'. This will highlight geometry which is failing to mesh. You will need to modify geometry at this location or change mesh sizing. nIf your meshing has special controls like periodicity, please check if those are correctly defined. nPlease search this forum and you will find plenty posts on meshing.Regards,nKeyurnnViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5454
3419
2473
1310
1022
