August 9, 2023 at 8:51 am
ikra nur hincal
SubscriberI get this error. I'm just learning how to do fluent meshing. I couldn't find how to fix this error. Can you help me? Thanks in advance.
ERROR:
Update failed for the Mesh component in Fluid Flow (Fluent with Fluent Meshing). The Mesh component in Fluid Flow (Fluent with Fluent Meshing) does not contain all entity types advertised in its component templeate, even after uptade.
August 9, 2023 at 1:49 pm
Federico Alzamora Previtali
SubscriberIt seems like you are running Fluent Meshing from Workbench. Did you change the topology of the geometry before updating the Mesh cell in your project?
7742
4490
2957
1449
1322
