Ansys Products
Ansys Products
Help!! Fluent Black graphic workspace
    • segs
      Hi
      I have a problem with the black screen in fluent (ANSYS Workbench: Academic Student Release 20.1):
      Please help I have tried all that I could, still not working.....please can someone explain in more ... and also i have no idea what msw is
      thanks
    • Keyur Kanade
      quick check on supported hardware
      https://www.ansys.com/solutions/solutions-by-role/it-professionals/platform-support
      if it is ok, are you able to open spaceclaim or meshing or fluent with graphics window?
      Keyur
    • Keyur Kanade
      also moving this to installation and licensing category to get better response.
      Keyur
    • segs
      Thanks for your reply, kkanade.
      YES, I can open SpaceClaim, design modeler, meshing and fluent with the graphics window.
      But the   '' Result @CFD post is all black graphic window''.
      Thanks
    • tsiriaks
      What if you set the following Windows environment variable
      environment variable name : QT_OPENGL
      environment variable value : desktop
Viewing 4 reply threads
