Tagged: calculation, immediate, no-result, plasma, wrong
March 8, 2022 at 3:04 pm
Randy92
SubscriberBackground:
I am trying to simulate a plasma reactor to map heat distribution and airflow. This is a basic 2D simulation and I started with the a fluid domain only and got the result I liked . See two pictures below. Note: the model represents only half of the reactor but I did not select Axis-symmetry.
March 9, 2022 at 1:28 pmKarthik R
AdministratorHello:
I'm thinking that you missed the Share Topology step in your geometry preparation. When you perform this, Fluent will automatically recognize convert the solid-fluid wall as coupled. Perhaps, this is what you are looking for Karthik
March 10, 2022 at 8:30 amMarch 10, 2022 at 10:10 amRob
Ansys EmployeeScroll up - what text is there above all of the "writing" section?
March 10, 2022 at 10:30 amRandy92
SubscriberThe problem is solved thank you all for answering!
Viewing 4 reply threads- You must be logged in to reply to this topic.
2706
2142
1355
1144
462
