Help for piezo property commands (APDL) code to find voltage??
    • alis
    • ravishek
      use Piezo and MEMS extension insteadn
    • HuiLiu
      Hi, you can check in your solve.out file to see if you have the coupled element properly defined, ie. element type solid226/227. If the element type is correct, try post-processing APDL command as alternative to plot the voltage: insert a command object - have a few lines like nset,last ncmsel,s, nameselction n/show,pngnplnsol,voltn
