Ansys Free Student Software
(Help) Licensing Issue encountered when running CFX Solver
    • Luke Baharie
      When attempting to run CFX solver, I am told that there is an error in line 2 so the solver aborted and this is the displayed information in the "file out" section of the solver.
      However, mine is the only user on this machine and this is the only time I have installed and used the software.
      I am running 2022 R1 since it is compatible with the systems at uni.
    • George Karnos
      Try the following:
      Download the Software (If you are using an older download of 2022 R1)
      Uninstall the Free Student version.
      Rename the directory:
      c:\Program Files\Ansys Inc
      to:
      c:\Program Files\Ansys Inc_Old
      Reinstall the Free Student Version by right click on setup.exe and chosing
      more->run as administrator
      Does this allow you to run CFX?
    • Luke Baharie
      It has yes, I assume the student version limits you to using 4 cores for the solver since using more encountered other errors
    • George Karnos
      That is correct...4 core limit.
Viewing 3 reply threads
