Help me please I’m student in 4th in university
    • fasilerrrrrr
      Now  I study  about  Dispersion of covid-19 in dental clinic then  I want to know how to create particle  out  of mouth  and dispersion around  the room  and  watch  flow  in air in the dental room . Could you help me to recommend me to setting  boundary  or method  for end my project 4th?  or  youtube channel for solve it .( Ansys fluent )
      Component in room
      Inlet air (big rectangle)
      exhaust air (small rectangle)
      patient
      Dentist
      assist dentist
    • DrAmine
      You can inject at first some mass less particles from a surface playing the role of the mouth of patient or from a small plane in front of it. Either you do it in that you or you use pathline after running the simulation and release from any surface.
    • fasilerrrrrr
      Can you describe boundary or method  in cfd fluent for me please   .   i  cant imagine  sir.
      Thanks so much
      It's not technically a boundary, have a look at Injections within the DPM model.
      Also have a look at HVAC models as the only difference between your model and an office space is the quality of the furniture.
    • fasilerrrrrr
      Thank you sir
    • DrAmine
      And: please make some tutorials to speedup the learning curve!
    • fasilerrrrrr
      why do i learning curve ? Could you explain  it.
Viewing 6 reply threads
