August 9, 2018 at 1:20 pm
WIZARDOUSS
SubscriberHello,
I would like to have a little help with a simulation of gas flow in a micro-channel involving slip flow boundary condition.
August 9, 2018 at 1:31 pm
DrAmine
Ansys EmployeePlease elaborate more on your question and try to be more specific. Which software are you using?
Finite Slip flow boundary condition is implemented in Fluent and CFX and PolyFlow.
Fluent Theory Guide: 7.2.3. Slip Boundary Formulation for Low-Pressure Gas Systems
CFX Modeling Guide: 2.7.1.3. Finite Slip Wall
August 12, 2018 at 12:18 pm
WIZARDOUSS
SubscriberHello abenhadj
thanks for your response I am using fluent 15.0
the probleme is
there is two chamber conected with a micro chanel
the two chambers contain nitrogen gas the pressure in the first one is 130000 Pa and in the second one 100000 Pa
the flow is rarefied and steady
August 12, 2018 at 12:42 pm
Karthik R
AdministratorHello,
I still do not quite follow why you cannot model the microchannel walls using the no-slip boundary condition. Could you please elaborate on your necessity to use a slip wall?
Thank you.
Best Regards,
Karthik
August 12, 2018 at 2:01 pm
WIZARDOUSS
Subscriberhi
comparing my result to previous work with different solver it is not the same
what it is mentionned in literature that rareffied gas flow in micro-metric geometries involve slip conditions as
the Maxwell based slip velocity and Smoluchowski based temperature
cordially
August 12, 2018 at 2:40 pm
Karthik R
AdministratorHello,
Thank you for this information.
I read a little bit on the information provided by Surya. You can use the "low-pressure slip boundary formulation" for your model. Please refer to the 'Theory guide' for more information. You should be able to activate this from Models -> Viscous -> Laminar. Once you activate the 'Energy equation', you should see this under 'Options'. Please note that this option is available only for laminar flows. Here is a screenshot.
I hope this helps.
Best Regards,
Karthik
August 12, 2018 at 3:07 pm
WIZARDOUSS
Subscriberthanks a lot
I have already used it when I was searching in the theory guide but no difference I get always the same results
the funny thing that when I use the turbulent model (k epsilon) I approach to the wanted solution but the flow is laminar
I searched on google for a tutorial of rarefied gaz modeling or michrochannel using fluent but there are not any
I did the same simulation whit COMSOL and it work but with fluent I am struggling with
cordialy
August 12, 2018 at 3:32 pm
Karthik R
AdministratorHello,
You have to explain what your exact issue is with Fluent. What should be the solution and what are you getting with Fluent? We will be better equipped to help you if we understand the nature of your issue. Until now, it felt like you were unable to set-up your slip condition in Fluent. Please provide the necessary plots / screenshots so we can assist you better to resolve your issue.
Regarding your results on COMSOL, unfortunately as ANSYS employee, I will not be able to comment on this.
Thank you.
Best,
Karthik
August 27, 2018 at 11:28 am
August 27, 2018 at 4:42 pm
Karthik R
AdministratorHello,
I have a few question regarding your problem set-up.
- What BCs did you use to solve the model? I am especially interested in the boundary conditions along the wall of the thin 1um region. Please elaborate your inlet and outlet boundary conditions as well
- What numerical schemes did you use to solve the problem?
- Could you please post an image of the grid?
Thank you.
Best Regards,
Karthik
August 27, 2018 at 5:41 pm
DrAmine
Ansys EmployeeTo add to the valuables questions of Karthik: which material model are you using?
August 28, 2018 at 10:23 am
Ansys EmployeeCan you also check the Knudsen Number and compare this against the range where continuum theory holds?
February 4, 2021 at 12:56 am
zhangdongjie
SubscriberHas your problem been solved? Where is the UDF loading of speed slip? Moving wall?n
2688
2138
1349
1136
462
