April 12, 2023 at 4:26 pm
jyosrimanaswitha
SubscriberI am working on Microstrip Antenna design in the ansys electronic desktop, I would like some help on understanding and plotting the cross-polarization and co-polarization of the same antenna design when plotting results.
Thanks for your help in advance.
April 12, 2023 at 10:33 pm
Connor Pope
SubscriberGo to "Results". Go to "Antenna Parameters". Select your choice of visualization, I prefer "2D".
Under category select "Realized Gain". From there, you should see at the bottom of the list "RealizedGainCoPolar" and "RealizedGainCrossPolar". You can plot both at once.
You can also plot the delta between the co and cross polarized gain as a function of frequency, by putting this in the 'Y:' part --> "abs(dB(GainCoPolar) - dB(GainCrossPolar))" <-- and selecting "Freq" as your primary sweep instead of theta or phi. You can select theta = main beam direction, and phi = main beam direction, and it'll calculate the delta between your co and cross polarization at that specific direction.
- Maxwell, HFSS or Q3D?
- Error
5242
3299
2469
