3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
HELP: Self intersecting or invalid profiles were ignored
    • Devayani Balkrishnan
      Hi, I'm very new to ANSYS and am trying to analyse compression stress on thin structures.
      I don't understand why the extrusion doesn't work correctly for some of my structures.
      Making the structure bigger generates this
    • peteroznewman
      I suggest you extrude those lines as zero thickness surfaces instead of solid bodies.  When you have the surfaces you need, use Shared Topology to make the mesh connect across separate surface bodies.  In Mechanical, you can assign the thickness to the surfaces that the shell elements will use.
