January 12, 2023 at 2:25 pm
Bharath Chodavarapu
SubscriberHello,
I was trying to simulate a simple DED simulation in ANSYS, I was using the manual clustering option, But it wasnt able to generate to it. Can anyone where exaclty it was going wrong? I am attaching the relavent information.
The file.out error message
*** MAPDL - ENGINEERING ANALYSIS SYSTEM RELEASE 2022 R2 22.2 ***
Ansys Mechanical Enterprise Academic Research
00000000 VERSION=WINDOWS x64 13:23:20 JAN 12, 2023 CP= 0.766***** MAPDL ANALYSIS DEFINITION (PREP7) *****
TURN OFF ELEMENT SHAPE CHECKING
NBLOCK format=(1i9,3e20.9e3)
NBLOCK read of 6120 nodes completed.
End Nodes
##################################################ELEMENT TYPE 2 IS SOLID185 3-D 8-NODE STRUCTURAL SOLID
KEYOPT( 1- 6)= 0 0 0 0 0 0
KEYOPT( 7-12)= 0 0 0 0 0 0
KEYOPT(13-18)= 0 0 0 0 0 0CURRENT NODAL DOF SET IS UX UY UZ
THREE-DIMENSIONAL MODEL
Start Elements
##################################################EBLOCK read of 19 nodes per line
Format= (19i9)EBLOCK input of 4047 elements completed
End Elements
CMBLOCK read of ELEM component PRINT_PART completed
CMBLOCK read of ELEM component BASE_PLATE completed
CMBLOCK read of ELEM component WELD_1 completed
CMBLOCK read of ELEM component WELD_2 completed
CMBLOCK read of ELEM component WELD_3 completed
CMBLOCK read of NODE component START_FACE_1 completed
CMBLOCK read of NODE component START_FACE_2 completed
CMBLOCK read of NODE component START_FACE_3 completed
CMBLOCK read of NODE component BASE_PLATE_UPPER_ELEMENT_FACES completed
CMBLOCK read of NODE component PRINT_PART_LOWER_ELEMENT_FACES completed
add named selection
CMBLOCK read of ELEM component PRINT_PART completedPARAMETER PRINT_CM_NAME = print_part
SELECT COMPONENT PRINT_PART
SELECT ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
816 NODES (OF 6120 DEFINED) SELECTED FROM
297 SELECTED ELEMENTS BY NSLE COMMAND.DEFINITION OF COMPONENT = _PRINT3D_NO ENTITY=NODE
DEFINITION OF COMPONENT = _PRINT3D_EL ENTITY=ELEM
SELECT ALL ENTITIES OF TYPE= ALL AND BELOW
PARAMETER _AM_CHECK_PART = 1.000000000
CMBLOCK read of ELEM component BASE_PART completedPARAMETER BASE_CM_NAME = base_part
SELECT COMPONENT BASE_PART
5304 NODES (OF 6120 DEFINED) SELECTED FROM
3750 SELECTED ELEMENTS BY NSLE COMMAND.DEFINITION OF COMPONENT = _PLATE_NO ENTITY=NODE
DEFINITION OF COMPONENT = _PLATE_EL ENTITY=ELEM
PARAMETER _AM_CHECK_TABLET = 1.000000000
PARAMETER _AM_PLATE_Y_TOP = 0.000000000
/INPUT FILE= scan_params.dat LINE= 0
PARAMETER VOLU_PER_STEP = 60.00000000
PARAMETER CLUSTER_MOD = 1.000000000
PARAMETER NO_WELDS = 3.000000000
PARAMETER SW_PICTURE = 1.000000000
PRINTOUT RESUMED BY /GOP
*** NOTE *** CP = 1.922 TIME= 13:23:20
THE 3 WELDS HAVE BEEN PROPERLY DEFINED.*** NOTE *** CP = 1.922 TIME= 13:23:20
THE 3 START FACE OF WELD HAVE BEEN PROPERLY DEFINED.*** NOTE *** CP = 1.922 TIME= 13:23:20
CLUSTERING WILL BE DONE FOR 3 WELD. CONTINUED.*** ERROR *** CP = 1.938 TIME= 13:23:20
Node 0 is not defined.
NUMBER OF WARNING MESSAGES ENCOUNTERED= 0
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1Thanks
Bharath
January 13, 2023 at 5:51 pm
John Doyle
Ansys EmployeeI see the message: “Error: Node 0 is not defined” at the end of your output.
Do all the named selections (components in MAPDL) have at least one element in them? Maybe your mesh is too course.
Are you able to run thru the example of manual clustering published in Section 5.7.1 in the Additive Manufacturing (R2022-R2)?
2130
1349
1136
461
