September 9, 2023 at 12:30 pm
September 9, 2023 at 3:40 pm
Nikhil Narale
Ansys EmployeeHello,
Ensure that you have assigned all the required Named Selections at the CAD level, if not already done.
Refer to the lesson 1 of this course (You may skip ahead to 8 minutes and 30 seconds).
https://youtu.be/1-HwPKBSoM0?si=jTmzGvuz0ZCa0-20 -
September 10, 2023 at 11:28 am
Aadya Goel
SubscriberThank you. I had to create the named selections in the faces of the car on the enclosure where the car was removed.
September 11, 2023 at 4:57 am
Nikhil Narale
Ansys EmployeeGlad you figured that out. There's also a workaround. If you've already assigned named selections to the car surfaces, when creating the enclosure, select the 'Create shared topology' option under Options-Enclosure. This will create and assign an equivalent named selection on the similar enclosure surface.
September 11, 2023 at 5:05 am
Nikhil Narale
Ansys Employee...later the faces can be unshared, while retaining the named selections on the enclosure.
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7592
4440
2953
1427
1322
