March 22, 2023 at 2:09 pm
NavalArch
SubscriberGood day,
I've got an error indicating that " HYDRODYNAMICALLY INTERACTING STRUCTURES HAVE MOVED TOO FAR FROM ANALYSIS POSITION MOVEMENT EXCEEDS 75% STOPPED AT TIME = 0.00 ". I am looking for any help regarding to understand this error and how it could be solved.
Thanks in advance.
March 28, 2023 at 8:32 am
Ashish Khemka
Ansys EmployeeHi,
Try using the same node positions for both AQWA-LINE and LIBRIUM. It should be quite quick to change to see whether this solves the problem.
Ashish Khemka
April 14, 2023 at 1:22 pm
NavalArch
SubscriberHi,
Thank you for your response.
How is it possible to check if the same node positions are being used for the both?
3363
2471
1310
1018
