Help with Ansys Steady State Thermal Analysis
    • mc77
      Hi! I have some questions about setting up the boundary conditions for steady state thermal analysis. I am modeling a copper cylinder at 250 C radiating to a heat flux gauge (which I model as a small stainless steel disk).
      Can I define two boundary conditions on one surface?
      Should I define temperature across the entire cylinder and then have it also radiating surface to surface with the disk, or should I only define temperature on the top half of the cylinder?
      On the top half, can I have convection, radiation and temperature as conditions?
      Finally, I am a little bit confused by the different outputs I can get from a solution. What is the difference between total heat flux and directional heat flux? And how do these differ from the results I get with a radiation probe on either surface?
      Thanks for the help :-)
    • Kishan Konannavar
      Hello
      For the sake of clarity and to get better understanding of the problem, could you please post relevant screenshots of your problem.
      Thank you
      Regards
      Kishan
      Forum Moderator
      Duplicate https://forum.ansys.com/discussion/39233/help-with-steady-state-thermal-analysis#latest
      Friendly suggestion, don't post in multiple threads. It annoys the moderators.
