August 30, 2018 at 4:47 am
xfeng
SubscriberHi all, I am attempting to model a 3D explosion in rock using AUTODYN via the SPH solver.
My geometry has been made in Design Modeller and symmetry planes have been added via mechanical to reduce computation time.
My analysis settings have been allocated to program controlled in both Mechanical and AUTODYN.
When I begin to solve my model in AUTODYN, AUTODYN is unable to proceed past the first cycle and crashes. No further information is given as to why AUTODYN has crashed.
I have attached my model, much help is appreciated if anyone has also encountered as similar problem and workaround before!
August 30, 2018 at 5:39 am
xfeng
SubscriberUpdate: When the model is not simplified for symmetry (i.e the model shows the full region of examination) I am able to run to cycle 4 before getting the following error:
Problem terminated .... no cell controlling time step
Additionally, when I go to the View -> Plots tab and examine material location, my model does not show up on any cycle other than cycle 0.
This is my error log:
Error! Problem terminated .... no cell controlling time step
CYCLE: 4, Time: NaN, Timestep: NaN controlled by Interaction, factor: 0
Converting JWL to Ideal Gas, Material: ANFO
CYCLE: 2, Time: 1.606E-02, Timestep: 8.414E-03 controlled by SPH particle: 84800, in Part: SPH
CYCLE: 1, Time: 7.649E-03, Timestep: 7.649E-03 controlled by SPH particle: 689, in Part: SPH
CYCLE: 0, Time: 0.000E+00, Timestep: 0.000E+00 controlled by SPH particle: 801, in Part: SPH
Initializing.....Please wait
WARNING! Global erosion settings are ignored for structured parts.
Checking model setup.....Please wait
Automatically saving model, results file option switched on
Outputs set
Loading complete
Loading data 70 Mbytes
Loading data 60 Mbytes
Loading data 50 Mbytes
Loading data 40 Mbytes
Loading data 30 Mbytes
Loading data 20 Mbytes
Loading data 10 Mbytes
Start loading data ...... please wait
Opening file H:ANSYSThesis_v5_jeong_filesdp0ATDATDadmodel_0.ad -
August 31, 2018 at 8:31 pm
Sandeep Medikonda
Ansys EmployeeHi,
Have you tried scaling the time step and delete any misbehaving SPH node:
SPH Cutoffs
These options let you set SPH cutoffs.
The default values are usually good if you are using the default units (mm, mg, ms). You may want to change one or more of these defaults if you are using some other set of units.
Limit density / Delete node
If the density of an SPH node drops below the minimum density or above the maximum density defined by the minimum and maximum density factor chosen for the material, you have the choice of either limiting the density to the cutoff density or deleting the node. Make your choice here.
Minimum timestep
Nodes that have a timestep below the minimum timestep will be deleted.
Sandeep
September 3, 2018 at 12:59 am
xfeng
SubscriberHi Sandeep, I have tried limiting SPH cutoff density to no avail.
I have created a working model by creating geometry through the ANSYS Autodyn standalone system.
Much appreciate your help!
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2616
2098
1323
1110
461
