August 10, 2019 at 6:10 pm
raul
SubscriberI am running simulations with HFSS-IE (Integral Equation Solver).
The simulations run fine when I only include a "standard" simulation setup, at a single frequency.
But when I add a "Frequency Sweep", I get an error and the simulation does not run. I get the message "Handshake to solver failed".
Any help with running frequency sweeps in HFSS-IE will be greatly appreciated.
Thank you in advance.
Viewing 0 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2656
2120
1349
1118
461
Top Rated Tags
