Help with maxwll integration with simplorer
    • sidharthpunia10500
      Hi All,
      Currently, I am trying to integrate Maxwell 3D design with circuits in Simplorer. I want to sweep some physical parameters (location) in Maxwell model, and derive power from Simplorer. Running with fixed parameters works, sweeping within Maxwell also works, but when sweeping integrated maxwell parameters in the Simplorer, it says "[Sim200]: error on set parameter". Do you have any idea about what is happening and what is the correct way to do the sweep?
      Attached are some related screenshots.
Viewing 0 reply threads
