3D Design
3D Design
Help With Stent Model for FYP
    • moseybyrne
      hi guys,
      im doing an FEA on a coronary stent for my FYP in college (Mechanical and biomedical engineering im GMIT Ireland)
      I have created a stent model using CREO parametric, but when I import my file into ansys it becomes distorted and the geometry does not look correct, how can i correct this?
      i have added an image of the model that is generated incorrectly and an image of what it should look like from creo.
      I have also added the IGES File.
      any help at all would be greatly appreciated!
      Thanks
      Mosey
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      please split the body in 5-6 parts in creo. also try to split some faces lengthwise. then export.
      Keyur
