March 4, 2022 at 10:13 am
Johannes94
SubscriberHello ,
For a given composite material I have calculated the substitute parameters in the three spatial directions using Material Designer (see picture).
To be able to check the results for correctness I wanted to do two modal analyses.
The first one contains the composite material and the second one the substitute material of the Material Designer.
According to my understanding, the modes must be found at the same frequencies. But as you can see from the pictures they are very different.
I hope someone can help me.
Thanks a lot!!
Results with substitute parameters
March 10, 2022 at 8:40 amAshish Khemka
You can fix one end of the plate to at least eliminate the zero frequencies. The material properties are not matching up and henc e you are seeing a difference in frequency. Please see if the following video is of any use to you:
Ansys Material Designer Example - Bing video
Regards Ashish Khemka
2620
2098
1323
1110
461
