Hershcel Bulkley Model in Fluent
    • MohamedKhaled1
      Howdy;
      Currently i am using Herschel Bulkley model in Fluent. One of the parameters required is the fluid critical shear rate; I do not know how this parameter can be computed. All experimental data reported in the literature that i have using Herschel Bulkley model is reporting n, k and tau and there is no mentioning of fluid critical shear rate value.
      Kindly i am asking how can i calculate this value or if there is a certain range i should work within.
      Note: I am working on Viscous non-Newtonian flow in a horizontal pipe
      Thanks in advance;
      MS
    • DrAmine
      Wiki article stating something else:
      https://en.wikipedia.org/wiki/Herschel%E2%80%93Bulkley_fluid
