September 4, 2022 at 8:08 pm
September 12, 2022 at 12:23 pm
Ram Gopisetti
Ansys EmployeeHi, did you have splits in your model, you need to split to have an mappable faces, or you may want to opt for ANSA or third party tools to have an proper meshing onto to solids.
Cheers, Ram
October 24, 2022 at 11:07 pm
Reno Genest
Ansys EmployeeHello,
Have a look at the LS-PrePost training:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/Training/Intro/
You can mesh this geometry using tet elements. Or, if you need hex elements, you will have to slice the geometry into sweepable bodies. There is more information in the training above.
Or, if you have access to Ansys Workbench, you can try using the Multizone meshing method in Mechanical to have hex mesh on this geometry. Or, you can use SpaceClaim to slice the geometry into sweepable bodies.
Reno.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2656
2120
1345
1118
461
