January 20, 2021 at 4:19 pm
Michaelmic
SubscriberJanuary 21, 2021 at 6:24 amKeyur Kanade
Ansys EmployeeYou will need to slice this body into number of bodies due those small patches. Then you will be able use sweep method. nPlease have a look at nPlease go through help manual for more details nThere are many videos on splitting the body in SpaceClaim as well. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynJanuary 21, 2021 at 9:38 amMichaelmic
SubscriberHi, nThanks for you reply. I can do that. But on the back side is several faces printed on it, which are not rectangular. I would like to work with virtual topology.Isn't there any other way to simplify the geometry for Meshing in mechanical? nJanuary 21, 2021 at 11:37 amKeyur Kanade
Ansys EmployeeTo get hex mesh, you will have to use splitting. nAfter that you can use VT if required. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5242
3299
2469
