June 30, 2020 at 6:09 pm
evapeimon
SubscriberHi everyone!
I am new in Ansys and I am finding some trouble to mesh this geometry. It consists on two boxes, one inside the other, and I would like to make an hexahedral structured mesh that is fine at the faces of the internal element and coarser as the distance increases. I have tried with CutCell but it makes me use the same size for all the elements and I don't know how to make the transition. Is there anyway to do it?
Thank you in advance!
July 1, 2020 at 12:43 am
Karthik R
AdministratorCould you try to provide a local mesh sizing for the inner cube? Perhaps a face or a body sizing? This should refine the mesh on the inner box, but the other box should use the global settings.
Please let me know how this works for you.
Thank you.
Best,
Karthik
July 1, 2020 at 5:51 am
Keyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
There are certain constraings on creating hex mesh like side faces must be mapable. Please go through help.
You can always create a tet mesh. There are different meshing methods. Please check following.
Keyur
July 1, 2020 at 5:52 am
Keyur Kanade
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3670
2552
1751
1226
582
