Hey everyone how are you guys doing I’m simulating a vapor chamber with two phase flow
    • 沙菲克
      and the error is like as mentioned please guide me where am I mistaken
          Stabilizing x-momentum to enhance linear solver robustness.
      Stabilizing y-momentum to enhance linear solver robustness.
      Stabilizing pressure correction to enhance linear solver robustness.
      Stabilizing temperature to enhance linear solver robustness.
      Divergence detected in AMG solver: temperature
      Error at host: floating point exception
      Error at Node 0: floating point exception
      Error at Node 1: floating point exception
      Error at Node 2: floating point exception
      Error at Node 3: floating point exception
      ===============Message from the Cortex Process================================
      Compute processes interrupted. Processing can be resumed.
      Error: floating point exception
      Error Object: #f
      Calculation complete.
      I'm good thanks, how're you? However your model has diverged. Check mesh quality (cell quality AND resolution), settings and whether the time step you used was sensible.
