October 23, 2018 at 8:55 pm
pcote
SubscriberHello,
How do you subtract an imported HFSS 3D component from an already placed part?
I designed a probe and exported it using "Create 3D Component..." Then I placed the 3D component in a new design and it intersects with the waveguide I am trying to probe. When I try to subtract the probe from the waveguide solids the "Subtract" option is not available.
Thanks,
Patrick
- Maxwell, HFSS or Q3D?
- Error
2616
2098
1323
1108
461
