January 20, 2023 at 10:53 pm
Meng Ke
SubscriberI have imported a design with two ICs on two ends ans ICs are connected through transmission lines. Then I ]have cut this design in the middle so it can be used to run the EM simulation with the IC pins to transmission line traces. However, I can't edit this cutout design, I can't modify or delete the transmission line traces.
1) Got an error messge "No destroyable item(s) were selected" when I selected the line and deleted it.
2) Trying to setup a port at the edge of transmission line edge by selecting the edge of the line and clicking "Port --> create", the error message showed " one or more selected edges are not valid for port membership".
Does anyone knows how to fix this?
Thanks in davance.
MK
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
459
