HFSS: Can we extract field solutions with mesh element position?
    • gayathrinip
      Does HFSS allow us to extract field solutions at specific mesh elements? Does this extraction include information about mesh element attributes as well? If yes to these questions, where is the option to do this?nThanks.n
    • AndyJP
      AFAIK, no. Mesh data is passed to field postprocessor and the field data can be calculated there for arbitrary position.nI may be wrong, by the way, But I never seen anyone getting a data for actual mesh nodes. Naturally, it should be in the field solution folder, but I never tried to decode what is stored there.n
    • rtk
      ,nThe aedt results/solutions folder do have files regarding the field-mesh details. But its not possible to export them to another external domain, if that is your work goal.nCould you please let me know what exactly you want to do with these mesh data?.nnBest Regards,n
