November 24, 2020 at 3:32 am
AndyJP
SubscriberIn the manual the modal coefficient is described as:nThese quantities are named ModalCoefficient(, ) where contains each of the names of the ports in the design and runs from 1 through thenumber of modes specified by the user.nBut in fact, it allows plotting only N-1 coefficients for every port, where N is the specified number of modes.n -
March 2, 2021 at 1:53 pm
Praneeth
Ansys EmployeeHi,
Thank you for bringing this point to our attention. The concerned team is looking into this and will update you as soon as possible once we get the response from them.
We appreciate your patience.
Best Regards,
June 21, 2021 at 12:58 pm
Praneeth
Ansys Employee.Hi,
We thank you for bringing this point to our attention. The online version of the manual has been updated accordingly.
Best regards,
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8762
4658
3151
1678
1456
