November 19, 2018 at 4:02 pm
mosaicsupport
SubscriberGood Morning,
Our users are experiencing a few different issues when trying to run their simulations. We have tried using the older Siebel portal, but was directed here. Here are the issues:
- The program will fail to open the help menu. All browsers are closed, so there shouldn't be a locking issue.
- Some users encounter a "Communication Failure: System 0" when running their simulation.
- Other users encounter a Broken Pipe error.
This is using the latest patchsets for Red Hat Enterprise 7.4 . We are unsure what exactly is causing all of these issues, but any help would be appreciated.
Thanks,
Mosaic Support
- Maxwell, HFSS or Q3D?
- Error
2564
2078
1291
1106
459
