May 9, 2023 at 4:19 pm
nikunj jain
SubscriberSolving adaptive frequency ..., process hf3d exited with code -1073740791
i am getting this error when i analyze my design . what does this error mean and how do i solve this
May 10, 2023 at 9:49 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys Learning Forum.
Please note that more information is needed to serve you better. Kindly share the accompanying information along with this error code in the messages window. Please share at which process of the analysis this error is triggered if possible to narrow down the possibilities.
Best regards,
Praneeth.
Forum Rules & Guidelines - Innovation Space (ansys.com)
- Maxwell, HFSS or Q3D?
- Error
5386
3367
2471
1310
1022
