February 21, 2022 at 5:45 pm
simon_phoelex
SubscriberHi there, I'm trying to use HFSS on Linux. We have both 2021.R2 and V19.1 installed - I'm seeing the same issue on both installations.
After setting up a simulation and launching it, ansysedt hangs at the "Setup1 Entity Check on Local Machine - RUNNING" stage.
In v19.1 the message is "Setup1: Validating point ID on Local Machine - RUNNING".
Has anyone seen this? Amy idea what might be the cause?
I transferred the design to Windows and it simulated ok - however I'm trying to develop an automated system and need to use the Linux version for this.
Thanks for any help.
February 22, 2022 at 10:50 amsimon_phoelex
SubscriberI have discovered the problem The project name had "/" characters in it which is a path delimiter in Linux but not Windows.
Removing the "/" characters from the project name fixed the problem.
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1793
1236
594
